Technics SL-1500C
- Biogon
- Gramofon: składak
Technics SL-1500C
Nowy temat na nowy gramofon, który wkrótce powinien być w sprzedaży.
Specifications
Technology for Rotational Stability
Coreless Direct Drive Motor
High-Precision Motor Controller
Construction for Vibration Tolerance
High-Dumping Turntable Platter
Rigid Cabinet Construction
High-Dumping Insulator
High Quality Parts
High Sensitive Tonearm
Detachable PHONO Terminal
Technics Definitive Design
Inherited SL-1200 Series
Turntable Section
Drive Method: Direct Drive
Turntable Speeds: 33 1/3, 45rpm
Starting Torque: 0.18N・m / 1.8kg・cm (1.56 lbs-in)
Build-up Characteristics: 0.7 s. from standstill to 33 1/3 rpm
Wow and Flutter: 0.025% W.R.M.S.
Turntable Platter: Aluminum die-cast
Diameter:332mm (13-5/64″)
Weight:Approx. 2.0kg (4.5 lbs) (Including Turntable sheet)
Tonearm Section
Type: Universal, Static Balance
Effective Length: 230mm (9-1/16″)
Overhang: 15mm (19/32″)
Tracking Error Angle:
Within 2° 32’ (at the outer groove of 30cm(12″) record)
Within 0° 32’ (at the inner groove of 30cm(12″) record)
Offset Angle: 22°
Arm Height Adjustment Range: 0 – 6mm
Stylus Pressure Adjustment Range: 0 – 4g (Direct Reading)
Head Shell Weight: Approx. 7.6g
Applicable Cartridge Weight Range:
[without auxiliary weight] 5.6 – 12.0g
14.3 -20.7g (including head shell)
[with auxiliary weight] 10.0-16.4g
18.7-25.1g (including head shell)
Head Shell Terminal Lug: 1.2mmφ 4-pin terminal lug
Terminals
Audio Output: PHONO (Pin Jack) x 1, EARTH TERMINAL x 1, LINE (Pin Jack) x 1
General
Power Supply: AC120 V, 60 Hz
Power Consumption: 8W (Approx. 0.2W (Standby))
Dimensions (W x H x D): 453 x 169 x 372mm (17-27/32 × 6-21/32 × 14-21/32 inch)
Weight: Approx. 9.9kg (Approx. 21.9lbs )
Accessories:
Turntable, Turntable sheet, Dust Cover, EP record adaptor, Balance weight, Auxiliary weight, Head shell, Cartridge(ortofon 2M Red), PHONO cable, Phono earth lead, AC power supply cord, Owner’s Manual
Specifications
High Quality Parts
Turntable Section
Tonearm Section
Offset Angle: 22°
Terminals
General
Accessories:
Re: Technics SL-1500C
Hm, czyli ten też będzie manualem? Myślałem że chociaż pół-automat.
- BRob
- Gramofon: SL 1710
Jakieś migające kropeczki na małym wyświetlaczu mogli zrobić, byłoby nawiązanie do serii 1300 - 1500 mk2.
Ale i tak wizualnie jest nieźle.
Ostatnio zmieniony 24 kwie 2019, 06:56 przez BRob, łącznie zmieniany 1 raz.
- Regsoft
Automatyka to dla nowych Technicsów wciąż jeszcze samo ZŁOOOOO
Nawet autolift można w nim wyłączyć (taki mały pstryczek przy cinch) ...
Produkcja w fabryce w Malazji ...
Ortofon 2M Red w cenie ...
VTA ...
Słabszy silniczek ...
Sensownie odłączany PRE ...
Zaraz ...
A gdzie odkładać EP adapter?!
wojtekf
Manualem z podnoszeniem ramienia na końcu płyty (tak przynajmniej donoszą w komunikatach prasowych i jest to zgodne z tym co widać tutaj w okolicach 5:45 https://www.youtube.com/watch?v=eSKAr4WI3hA)
The story so far:
To nadal jest pół-automat
Czyli jednak dobrze pamiętałem
E, ten nie ma suwaka. Kicha
i popelina.
(od razu napiszę, co by nie wracać: nie wiem czy PJ miał
bo niby skąd? Hipciu wie!)
wojtekf
SL1500 przecież nigdy nie miał
The story so far:
ISOPHON
Stylistyka bardzo ładna bez niepotrzebnych "pierdołków" (pitch) ale czemu egzemplarzowi na filmie talerz faluje ??? hehe..jakość XXI wieku.Niespecjalnie mocno a..jednak..ociupinkę..
Batiar
- Gramofon: Technics SL-5200
Bardzo mi się podoba ten model.
Żadnych niepotrzebnych "udoskonaleń" czy wajch, czysta technika wręcz ascetyczny wygląd.
Od czasu do czasu szukam w necie czy już jest w sprzedaży bo mój SL-5200 to już staruszek.
Dzisiaj przeglądając internet znalazłem to :
https://www.easylounge.com/platine-viny ... lver-66533
Napisałem czy jest już dostępny i odpowiedzieli, że owszem ale tylko na zamówienie i że Technics zapowiedział dostępność tego modelu 22 maja.
Cena nie jest (moim zdaniem) wygórowana i myślę się szarpnąć na to czudo.
- Obywatel
Nie jest to ani odrobinę argument przemawiający za zakupem SL-1500C.
ISOPHON
Trudno powiedzieć jak jest jakością wykonania.Ilość filmów i skarg(np.na vinylengine) na "falulące" talerze Technicsa całkiem spora..
Niby silnik o lepszej konstrukcji w porównaniu do starszych "wypustów"(cewki bezrdzeniowe) ale to już było..w latach 70.
DUAL 701 korzystał z takiego silnika-identyczna konstrukcja ale mechanicznie lepiej wykonany(konstrukcja zewnętrznej niemieckiej specjalistycznej firmy "silnikowej"-PAPST).Oczywiście w DUALU świadomie zrezygnowano z kwarcowej kontroli obrotów.
Batiar
Myślę, że znajdzie się kilka argumentów.
1. Postęp! Nieunikniony, nowe rozwiązania, nowe technologie, nowe materiały
2. Precyzja i jakość wykonania! Jeżeli Technics w latach 70-80 zachwycał precyzją i jakością wykonania to zakładając że utrzymują dobrą tradycję to myślę, że obecnie poziom ten będzie wywindowany w kosmos.
3. Coś trzeba wnukom zostawić w spadku....wtedy będzie to sprzęt "vintage"... + 40-letnie płyty!
- Obywatel
ad 1. Postęp oczywiście jest, ale producenci nie bardzo chcą się nim dzielić w produktach budżetowych.
ad 2. Patrz punkt 1. A wręcz bym powiedział, że w produktach budżetowych jakość materiałów i jakość wykonania jest celowo obniżana. W porównaniu z latami '70 producenci w dużo większym stopniu zdają sobie sprawę z tego, że trwały produkt niekoniecznie jest kluczem do sukcesu biznesowego. A wręcz przeciwnie - żeby interes się kręcił, ludzie muszą dużo wyrzucać i dużo kupować. W dzisiejszych czasach "planowemu postarzaniu" nie podlegają tylko bardzo drogie produkty, a i to bym nie dał głowy.
