Technics SL-1200Mk7
- Biogon
- Gramofon: składak
Technics SL-1200Mk7
Nowy temat na nowy gramofon, który wkrótce powinien być w sprzedaży.
Specifications
Technology for Rotational Stability
Coreless Direct Drive Motor
High-Precision Motor Controller
Construction for Vibration Tolerance
High-Dumping Turntable Platter
Rigid Cabinet Construction
High-Dumping Insulator
High Quality Parts
High Sensitive Tonearm
Detachable PHONO Terminal
Technics Definitive Design
Inherited SL-1200 Series
Turntable Section
Drive Method: Direct Drive
Turntable Speeds: 33 1/3, 45rpm (with switch 78 rpm)
Starting Torque: 0.18N・m / 1.8kg・cm (1.56 lbs-in)
Build-up Characteristics: 0.7 s. from standstill to 33 1/3 rpm
Wow and Flutter: 0.025% W.R.M.S.
Turntable Platter: Aluminum die-cast
Diameter:332mm (13-5/64″)
Weight:Approx. 1.8kg (4.0 lbs) (Including slipmat and slipsheet)
Tonearm Section
Type: Universal, Static Balance
Effective Length: 230mm (9-1/16″)
Overhang: 15mm (19/32″)
Tracking Error Angle:
Within 2° 32’ (at the outer groove of 30cm(12″) record)
Within 0° 32’ (at the inner groove of 30cm(12″) record)
Offset Angle: 22° • Arm Height Adjustment Range: 0 – 6mm
Stylus Pressure Adjustment Range: 0 – 4g (Direct Reading)
Head Shell Weight: Approx. 7.6g
Applicable Cartridge Weight Range:
[without auxiliary weight] 5.6 – 12.0g (14.3 – 20.7g (including head shell))
Head Shell Terminal Lug: 1.2mmφ 4-pin terminal lug
Terminals
Audio Output: PHONO (Pin Jack) x 1, EARTH TERMINAL x 1
General
Power Supply: AC120 V, 60 Hz
Power Consumption: 8W (Approx. 0.2W (Standby))
Dimensions (W x H x D): 453 x 169 x 353mm (17-27/32 × 6-21/32 × 13-29/32 inch)
Weight: Approx. 9.6kg (Approx. 21.2lbs)
Accessories:
Turntable, Slipmat, Slipsheet, Dust cover, EP record adaptor, Balance weight, Head shell, Screw set for cartridge, PHONO cable, PHONO earth lead, AC power supply cord, Owner’s Manual
Specifications
High Quality Parts
Turntable Section
Tonearm Section
Terminals
General
Accessories:
Re: Technics SL-1200Mk7
Ale mieszają
To jak to będzie? G > GR > mk7 ?
+ przynajmniej headshell ma logo
- Biogon
- Gramofon: składak
Mk7 będzie produkowany w Malezji. Targetem ma być DJ. Tylko wersja czarna. Cena pomiędzy 4 a 5k. UWAGA! Może grać do tyłu!!!
Czarny. Q`rde, to powinien być SL-1210mk7
a gdyby dali złacze USB do maców, to wtedy SL-i1200 OS7.
Jak gra do tyłu czyli jednak inaczej, to SL-1200LGBT
- Biogon
- Gramofon: składak
Darek, pewnie Cię również ucieszy możliwość zmiany koloru podświetlenia
Złącze USB ma
Złącze USB ma
Generalnie musi być dobra sprzedaż i popyt skoro tak prują do przodu z wprowadzaniem nowych modeli.
- Biogon
- Gramofon: składak
Chcą ogarnąć szerszą grupę odbiorców. DJ-ty nie chcieli kupować G/GR ponieważ jest za drogi a równolegle na rynku jest kilka milionów używanych Mk2-5. Mk7 ma tę lukę wypełnić. Stąd nazwa Mk7
1500C to sięgnięcie po klientów Regi, ProJecta itp... Po co wydawać 4k na paskowca z dykty jak można kupić metalowego Technicsa z nowoczesnym DD i VTA. A nisza winylowa rośnie i w skali globalnej to już jest konkretny kawałek tortu.
- Biogon
- Gramofon: składak
- Gramofon: PD-300
Jakie ramię wstawisz ?
- Biogon
- Gramofon: składak
